If I put your problem in simple words, you mean:
when working in 5G WDS mode, AR750 has to set channel in its AP in order to have its wifi broadcasting, right?
Auto channel may have problem I think. This is expected.
Yes, in simple words is that. But sometimes Auto channel connects in 5G WDS Client in one or other router…sometimes…and it always get stucked in 5.000Ghz like the picture, not another frequency in all the channels I tried.
Thx for your reply!!
FORCE VPN NOT WORKING !!!
Tested version: gl-ar750-3.006-1115
Today i surprise to surf around without VPN IP:
That need to be fixed.
I cannot understand your English but I think you are saying that if you try and change server manually, the real IP leaks,
This is the reason we need the Force VPN option bought back (ie. manual instead of automatic).
Also, very similar to the leak I reported here:
I didnt tell and dont mean like this.
I told abbout: The automatic “Force VPN” function from v 3.006 dont work.
I can’t reproduce the leak. As far as I can tell, once connect is clicked, then the VPN is forced.
Obviously, if you click “disconnect” then that “un-forces” the VPN until you then click “connect” again.
That is the reason I asked for a “re-connect” button to be added and the Force VPN check box to be re-instated.
Regarding the VPN section:
You cannot change server in current config in Management Tab while connected to said config (this may be intentional but you can do it in the Status Tab).
When you click the change server cog (Status and Management Tabs) it would be better and more logical to open with the screen scrolled so that the current server is shown.
Bugs on gl-ar750-3.009-1129.bin
2.4 GHz WLAN:
5 GHz WLAN:
I was about to post how the Repeater Function in an environment where an SSID has many BSSIDs (i.e., hotels and other public spaces) on my AR-750S has been disappointing with the latest series of 3.X firmwares; first there was the necessity of having to manually reconnect, which was fixed, but now there’s times when I get no connectivity for long pauses and I’m assuming that’s when it’s roaming between BSSIDs and I just don’t remember 2.72 having this issue.
But if these WLAN “bugs” are actually features to help fix that, they’re welcomed (and I’m speaking purely from conjecture here from looking at the changes you’ve cited, which actually could be part of a strategy to reduce Intra-BSSID roaming times- I haven’t had a chance to try it out yet).
Packages lists Updates Problem
AR750 (WDS mode)
gl-ar750-3.009-1129.bin.
Cannot update *ipk packages from WebUI on my 2 AR750 routers (says Network unreachable) but can update successfully from Luci. DNS is set to xxx.8.1, the WDS AP.
Why is this happening now with this new firmware?
With gl-ar750-3.006-1115 *ipk updates were ok in both AR750 (WebUI and Luci)
AR750S (the WDS AP)
gl-ar750s-3.009-1129.tar
On AR750S packages Update ok (WebUI and Luci).
Thx
Update 09-12-2018
AR750
Same on last testing firmware gl-ar750-3.009-1206. Not possible to Update or install *ipk packages from WebUI. Network Unreachable pop-up. Only possible from Luci.
Thx
Update 12/01/2019
With last firmware gl-ar750-3.012-0111 the problem is solved. WebUI can Update packages lists and install from there also.
Thx
No found any issue. Could you try to reset factory settings by holding the reset button for 10 seconds? All is good for me.
AR750, gl-ar750-3.009-1129.bin.
My current situation:
It looks a little bit like the configuration on Admin menue and on Luci are different. David reported a bug which sounds like the same.
Admin menue: Missing channels on 5 GHz
At the same time the channels not missing on advanced admin menue on 5 GHz
Admin menue: Missing some speed modes on 5 GHz
I cant check do factory reset, and cant check today the real WLAN speed for limitation to 150 MBit or not. If we need, i will check later.
File Sharing configuration Erased at boot on AR750S
On every boot/power up, any file sharing setup with Luci is removed and the default sharing options are used. This is a problem especially when the share was set up with no guest access, and to require a user name and password for access. The (default) setting after reboot allows read only access to the guest account with no password required. In Luci, the previously set “Allowed users” field is also cleared.
The problem apparently is in the file /etc/hotplug.d/block/50-samba which is run at boot.
Now i have found different on Admin menue and Luci. I describe it on follow sample:
I guess, other actual discussed AR750 (white) bugs will be releated on the same differents of Admin values and Luci values.
The GL webui is different from luci.
channel issue: GL webui has filtered DFS channel, while luci show all support channel.
speed mode: yes, there is missing some speed mode, GL webui can only select the highest speed. If it is necessary, we can add more speed to select.
wlan speed limit to 150: It works for me. Not sure why you only get 150, maybe it is limited by your laptop’s NIC.
txpower issue: It read the value from the driver, but it depends on hardware, please take the GL webui as the standard.
The handling of 2,4 GHz and 5 GHz are different on GL Web UI:
I dont know which handling are better. A booth WLAN frequencys should handled on same best way.
With same AR750 and same Laptops i get with old 2.2x GL firmware:
I dont find button for deactivate “WLAN coexistence” on 3.x firmware. It can be the low speed its depend on this. After deactivating “WLAN coexistence” the speed was about the double on 2.2x firmware.
Yeah, we will add more speed mode for 5GHz.
There is a problem that the personal setting will be lost after updated to new firewares, which were released recently, from gl-mifi-3.008.bin to gl-mifi-3.009.bin . Like SSID, wifi-Key and lan ip.
At the first time after update fireware, the setting information will remain effective. But if I shut down the router then the setting information was lost. Then visit the router must from the origin Lan IP and set the language.
Is it possible that you have more data or software packages installed on the router? If the router storage is full it cannot mount and find the configurations.
For data lost automatically, I do have a few reports from users in the past several years. But non is replicated and verified. So I cannot tell the reason.
I think it’s not caused by storage. It has not appeared in the pre version.
