The issue is that most of the devs don’t speak good english. This means you need to have a public tracker in english, copy over all the data to the internal one, then when things are done copy it back.
Then there was a flood of users posting the same issues over and over without searching. So there needed to be double moderation, here on the forums and on the bug tracker as well. GL having to search for issues here and there. That was unsustainable.
A lot of extra work, without much benefits. This extra wasted time can be used to find and fix bugs and add features.
So right now, users can continue to post bugs and features they want here on the forums, the GL team will then confirm the bug and add it to the internal tracker to fix it.
Please don’t make a lot of threads on the same issues, and don’t post the same things over and over, it will not help your cause. Post once, and it’s done. Use the search.
