make[1]: *** No rule to make target 'package/cgminer/compile
Can anyone with more experience tell me how to make it work?
Or point me to useful resources? I’m lost, and have never done cross-compilation before. I was hoping the gl-inet/sdk would ease the process, but there’s evidently something missing in my understanding of how to use it.
OpenWRT Packages have a special kind of Makefile, that will either download a remote package and build from the downloaded sources, or build locally. It will create the IPK package you can install on the router, and contains install locations, files and so on.
I found a package source for CGMiner here:
It will need to be modified since the person is using it for Avalon, i guess some specific miner hardware.
I’m well aware that this is a lost cause, but the whole point of the exercise was for me to run a low-power device around the clock with internet connectivity and a USB port for my NEWPAC miner. This is just a miner for luck, with intergalactically small odds of mining any block ever.
I knew all that when I was getting into this.
But I was getting nowhere with OpenWRT and so I wrote this question in the forum before giving up and throwing everything away. You took the time to respond and I’m thankful for that.
So I shall try. And it will be wasted time. And that is OK.
I managed to get a bit further, but I’m not quite sure how to fix this missing dependency
root@MT300N-V2:~# opkg install cgminer_git-9e51f0b-1_mipsel_24kc.ipk
Installing cgminer (git-9e51f0b-1) to root...
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for cgminer:
* udev *
* opkg_install_cmd: Cannot install package cgminer.
I tried (when building the ipk)
$ scripts/feeds install libudev-fbsd
And I tried changing +udev to +libudev-fbsd in the cgminer openwrt Makefile’s
DEPENDS:=...
to no avail.
I don’t quite understand how the dependency on udev is detected, and whether it is a dependency on a library or a daemon, and whether there is an openwrt package for either. My guess of libudev-fbsd was just a crap shoot based on the package description.
