You’ve used to provide a custom image builder for your MT300N-V1 routers, however I can’t find one for MT300N-V2 routers. The LEDE ramips mt7620 image builder does not have profile for MT300N-V2 either.
How can I build a custom image for MT300N-V2?
Can I re-use my V1 code for slider polling/switch actions or has anything which had to do with buttons changed between V1 and V2?
Thanks for your work and update - Also waiting on this so we can build and order <span style=“color: #222222; font-family: source_sans_proregular, ‘Helvetica Neue’, Arial, Helvetica, Geneva, sans-serif; font-size: 14.6667px;”>MT300N-V2</span>
@pavan4, by default it is ar71xx so you will not find target for MT series. Pleas change the architecture to ramips, then choose 7620 boards, you will find GL-MT300A GL-MT300N
@alzhao I might be going off thread here. My apologies.
However, I chose 'Ralink RT288x/RT3xxx ’ as target —> MT7620 based boards as subtarget —> I can’t find MT300N in the Target Profile. There is only default and that is still the wrong architecture after I compile.
So I’ve finally received my v2 and making a default image without any customizations (make image profile=mt300nv2) produces a file (lede-ramips-mt7628-gl-mt300n-v2-squashfs-sysupgrade.bin) which when flashed onto v2 unit results in a boot loop – the v2 tries to start up and then reboots.
I’m thinking something’s amiss in the image builder you’ve posted, could you please clarify.
Oops, spoke too soon. I have re-downloaded the image builder posted on August 11th, however I’m still getting errors starting wifi:
root@mt300nv2:~# wifi
/sbin/wifi: eval: line 1: uci2dat: not found
killall: ap_client: no process killed
killall: 8021xd: no process killed
uci: Entry not found
WiFi is not working properly, it starts with the LEDE ssid (instead of the SSID I’ve set).
