Particularly, on the AR300M, the little button next to the rest button - what does it do?
Regards,
Glitch
Regards,
Glitch
This switch doesn’t have default function. It is only used for special purpose or you configure it.
For AR300M, in the newest uboot, it can be used to choose Nor or Nand firmware to boot.
Hi alzhao,
The button does not seem to work on my router 300a. Would you happen to have the latest uboot file for it? Thanks
Do you mean the reset button? It should works. In newest firmware, the middle LED will blink if you press it down.
We didn’t change uboot .
