Bypass Virgin Box
Hi i bought a flint wireless router can i set it up as a 2nd router to bypasss my virgin box please i know i need put my virgin into modem mkde but unsure what else i need to do help
If you connect the ethernet cable coming from your ISP router
1-on the Wan port put your Flint on router mode,
or
2- if you connect it on any of the ethernet port 1-4 put your Flint on access point mode
Then do i open vpn up nn sign into a vpn as need it as having blocks ps what level nord do i need top middle or basic
Do you use Virgin Media UK?
Virgin media Box need to make a modem mode. Then connect the cable to wan flint router. Should be automatic by dhcp from Virgin media.
Not sure, I never had nord vpn, but I’m guessing any one should work :call_me_hand:
