Is it possible with the AR 750S ext make password protected connection on an camping and the order device also connected without an password on the same connection.
Thanks you die the answer.
Edwin.
Edwin.
Yes it does this. Connect it to camp WiFi as Repeater and it has its own WiFi.
With one password for alle devices ?
If you mean the password on captive portal, pls refer to
After you connect repeater you will be able to connect all devices.
