A little while ago I bought a GL-SFT1200 (Opal). This is spec'd with 3 Ethernet ports, 1 designated as WAN and two others specified as LAN. That was perfectly acceptable for the purpose I was using it for, but I am now looking to repurpose the device, but I need it configured so that it has 2 WAN connections and 1 LAN connection. Is this possible to do with this device or do I need to purchase a different device?
Not possible by gl ui settings.
But possible with some experience to openwrt and luci.
but can you elaborate what the purpose is for two wans?
do you want a fail over?, is it bonding?
The intention is for fall over.
Alas, as you may realise, I am quite new to openwrt, so at present have only explored what is visible on the web page. Anything else I will probably need a lot of pointers to the howtos.
What type of WAN connections, DHCP, IPoE, PPPoE or Manual?
