Modem connected to GL-AR300M WAN port via LAN cable
NAS drive connected to modem via LAN cable
GL-AR300M connected to internet via VPN
PC's connected to GL-AR300M via WiFi
In GL-AR300M if I don’t select ‘No Internet if VPN is not connected’ I can access the NAS drive via WiFi on all PCs. However, if I select ‘No Internet if VPN is not connected’ then the NAS is no longer accessible. Is this correct functionality, as ideally I would like to leave ‘No Internet if VPN is not connected’ selected but still have access to my NAS.
Could I suggest a feature request whereby it’s possible to select this option but still have access to internal networks? Am I correct in thinking that with this option unselected if my VPN connection fails then everything connected to the router will have access to the internet without going through VPN?
Currently I can access both the internet and NAS if “No Internet if VPN is not connected” is not selected. What I want is to be able to access both when it is selected so if the VPN connection drops while connected to the internet then the internet connection also drops but I still have access to the NAS on the local network. Does this make sense or have I misinterpreted the logic?
