Some people set up a home server through Wireguard but don't want to disclose their home IPs to others. It is possible to mask your home IP when accessing your home network through a Wireguard tunnel.
Please go to the VPN Dashboard of your Client router. Then Choose Customize Routing Rules on Global Proxy
Then click the "double Arrows" on the right side of OpenVPN client. Put 0.0.0.0/0 and link inside and check out.
After that click the "double Arrows" on the right side of Wireguard client. Put your server LAN IP (Your home network) and link inside and check out.
Enable both Open and Wireguard.
You can access your Home LAN by the LAN IP you input, in here it is 192.168.188.X and when you browse the internet, others will only see your OVPN virtual IP.
So you can access your home network and browse the internet under the protection of a commercial VPN.
