We do have wall mount but it is for business customer currently. Since you need to buy it with x750 we will check if it is possible to add it to our web store these days and inform you here when it is available.
Thanks but I have since purchased Teltonika RUT950 routers that have a wall mount included. If you do end up having a wall mount available please update this thread and we may use one of these in a future project.
You need to order them separate then, or just order from the GL store.
Alfie put that bracket specially for you on the store. For it to show up in the amazon stores, a pallet must be sent to their locations, not something they will do for 1 bracket.
Wall-Mounts for the Brume/Creta/Slate form factors would be good - alternately I suppose strong hook/loop tape (aka Velcro ™) might work for them, as well as Mango/Shadow/White.
For my side project - we turn ar150 upside down, using the “tophat”, e.g. upper case to fasten to the box, rather than the “skateboard” bottom lid - the box being a weatherproof Pelican case along with a 4G LTE modem card and ethernet.
