I have an AR750S EXT and I installed the OpenWrt firmware but I dont like the UI, is there a way to revert the firmware or install the latest GL.iNet firmware?
Using Mac OS X I’ve tried the debrick process to reinstall the GL firmware: Debrick via Uboot - GL.iNet Docs
I see the lights flash 5 times, then release the reset button, I’ve changed my IP address to 192.168.1.2 but I am unable to access the UI at http://192.168.1.1
The instructions are a bit vague in terms of when you’re in uboot mode. Please ignore the number of seconds to hold the reset button down. When the left and middle leds are solid you will be in uboot mode and you can release the reset button.
I do see the power and 2G lights are solid and then release the reset button, but when I set my Mac IP address to 192.168.1.2 and try to access http://192.168.1.1, there is no web access for uboot. The browser just hangs.
I have the ethernet plugged into the WAN port on the router
I tried adding 192.168.1.1 as the router gateway but it didn’t help.
The current OpenWRT version is:
[Powered by LuCI openwrt-18.06 branch (git-18.196.56128-9112198)](http s://github.com/openwrt/luci) / OpenWrt 18.06.0-rc1 r7090-d2aa3a1b62
However, when I try to flash either one of those images using the OpenWRT I am getting the error:
“The uploaded image file does not contain a supported format. Make sure that you choose the generic image format for your platform.”
And I am unable to find any image anywhere that will load without the same error message above.
Here is the output from mount and df:
root@OpenWrt:~# mount
/dev/root on /rom type squashfs (ro,relatime)
proc on /proc type proc (rw,nosuid,nodev,noexec,noatime)
sysfs on /sys type sysfs (rw,nosuid,nodev,noexec,noatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,noatime)
/dev/ubi0_1 on /overlay type ubifs (rw,noatime)
overlayfs:/overlay on / type overlay (rw,noatime,lowerdir=/,upperdir=/overlay/upper,workdir=/overlay/work)
tmpfs on /dev type tmpfs (rw,nosuid,relatime,size=512k,mode=755)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,mode=600,ptmxmode=000)
debugfs on /sys/kernel/debug type debugfs (rw,noatime)
I also tried the uboot process again after the firmware update but still unable to connect using a Mac. But its fine now because the firmware update worked. I want to test the uboot process with a windows computer but unfortunately I dont have access to one right now.
