Hello all,
I have a GL inet router. I am looking to add a GL-MT3000 (Beryl AX) to my existing network.
I want to have the Beryl as a separate SSID using Wireguard VPN so if any devices want to browse the internet behind a VPN, they would select the Wifi SSID of the Beryl.
Is this possible? Been searching and not able to get a clear answer. Thank you.
Yes. I have done this with GL inet routers, configuring a VPN client on the second router and plugging the WAN port of the second router into a LAN port on the primary router. Clients that connect the second router use the VPN. But since only specific clients in my home need the VPN, instead I moved to using a single router with VPN policy routing by client. But using two routers works.
Thank you, steep01.
I take it that I would set up as an access point on the Beryl? Or is there anything else I would need to do on the Beryl admin panel?
Here is what I did:
Cable modem->RouterA->RouterB connected by wired ethernet.
Let’s say RouterA wifi SSID is named Home, RouterB wifi SSID is named Home-VPN. Clients connecting to Home use the home internet gateway. Clients connecting to Home-VPN use the remote VPN server gateway.
I used router mode on both. AFAIK, Access Point mode disables VPN. So only admin panel config VPN client setup and wifi SSIDs are necessary for this to work, unless I forgot something.
So in this configuration, by default RouterA clients are isolated from RouterB clients. If you need RouterA clients ↔ RouterB clients, then more configuration is necessary.
Thank you for the detailed answer, steep01!!
