I want to use the Beryl AX as a wifi client with two interfaces that act in failover mode with each other (WAN = 2x wifi, LAN = ethernet). I could not find a lot on whether you can even use the two band/antennas as separate radios/interfaces?! My idea was to use Multi-WAN or mwan3 to combine the two interfaces. Does that sound possible?
My use case is that I have a fast moving setup (think a notebook) that will jump between multiple overlapping APs. I want one radio to eagerly roam to the best signal AP and one to act as a failover that will stick with the current AP for much longer even if the signal is subpar. I would set the fast roaming interface as prio 1. Is that possible? It does not seem like you have an easy way to set a minimum RSSI threshold for interfaces with OpenWRT, right? Can i do that with a script, checking every few seconds if the “fast” radio has low signal strength and then restart it with wifi down/up?
Thanks for any help or suggestions!
