For the best stability and performance, we recommend using the original power adapter included with your Beryl.
If you would like to use another USB-C cable and power adapter, please make sure they meet the power requirements of your specific Beryl model:
GL-MT1300 (Beryl): 5V/3A
GL-MT3000 (Beryl AX): 5V/3A
GL-MT3600BE (Beryl 7): supports USB-C PD input at 5V/3A, 9V/3A, or 12V/2.5A
Please note that some phone or tablet chargers may not provide sufficient power for the router. We recommend checking the output specifications of the charger before use.
