the last couple of days i was trying the new beta for S1300 (qsdk-s1300-3.203-0527).
Anyway - i want to go back to qsdk-s1300-3.105, made a factory reset before flashing qsdk-s1300-3.105, and the router doesn’t boot anymore. Only the power led is on.
Debrick via uboot does not work. i can reach the uboot-gui, can upload the qsdk-image, the S1300 reboot - but that’s it. Only the power led is on. I have tried it with image 3.203-0527 as well - same result.
connected device overview doesn’t work well
—》 Can you describe it in detail?
minidlna doesn’t serve files after a reboot
—》 This is because the USB mount point has changed.This is bug.
Hi lizh,
in the connected device overview, a lot of connected devices often not shown or in the wrong place (disconnected). My main connection via lan-cable was always shown as a disconneted device.
Clearing the table of disconneted devices often gave me an error message (but i can’t remember the exact message).
These problems happened on both of my S1300 with firmware 3.203-0527.
