Can not make changes or connect to Guest Network
I’m trying to turn my Guest network back on so my devices that can’t accept the highest security sttandatd for the WiFi password, can still connect to the my LAN.
Howeve every time I make the slightest change to the guest network configuration , my whole lan shuts off.
Not to mention, for some reason the guest network no longer provides an ip to clients via dhcp.
Anyone have an idea on what to do troubleshoot this other than :starting over??
I just don’t understand why it’s not providing ip addresses when it worked fine before.
I presume you've tried reboot and setting everything back the way it was before you changed stuff and it still does it?
If so you're best just resetting it to factory and starting over before you brick it completely, which I've done before today..
Hi thanks for replying. Yes, I did try rebooting. Issue remained. However I did manage to fix it temporarily it by loading up and re flashing another copy of the firmware. Sadly this was not permanent. The next thing I did was completely erase and reinstall and still…guest network has weird connection issues. Often iOS tells me the network has no internet connection. Not sure what to do.
Please provide additional information, see How to get support quickly
