My Spitz is connected to ATT with a SIM card AND as a WIFI repeater. The WIFI has much higher speeds in the present location, but the Spitz seems to try and use the ATT connection instead.
Is there a way to configure the Spitz to choose the highest speed when connected to these two sources?
Hello.
I don’t have an X750 Spitz. I tested with AR750 Creta and AR750S Slate some time ago configuring 2 WANs.
You can install luci-app-mwan3 and set the two interfaces to 50% each or 75% one and 25% the other. Find out how to configure mwan3 on Youtube. There are easy to understand tutorials.
I’m not sure it will work, but you can give it a try.
Anyone can advise better than me.
mwan3 with metrics and weigths to give more or less priority to interface in Luci
Luci>Network>Load Balancing>Members
