I plugged my home network into my Beryl’s WAN port. I used my router’s reserved feature so the Beryl always gets the same IP. I can in fact ping it from a device on my home network, but I can’t browse to the IP address.
If i connect to the Beryl’s WiFi, then I can browse to that IP address or 192.168.8.1 and I’ll get the admin login page. What’s blocking this and how do I unblock it?
To gain access to the admin page from the WAN side, you have to add a port forwarding rule for TCP Port 80 from WAN to LAN IP address 192.168.8.1. You have to connect to the Beryl’s wifi, then go to Admin Panel → Firewall → Port Forwards. Use the WAN IP address to access the admin page, which then gets forwarded to the LAN IP address.
You may consider adding port forwarding for TCP Port 22 also, which will allow you to SSH and WinSCP into the router.
That does not work for the Slate AX? I have both ports forwarded to 192.168.8.1, but if i try to access the IP that is assigned to the Sate by the main router (connected LAN of main router to WAN port of slate) then it times out.
Either open the port , or forward the port to the LAN interface IP address and port.
Open ports 80 (HTTP), 443 (HTTPS) , 22 (SSH), 8080 (Luci) as needed. Your home network is a WAN network for this Beryl.
Accessing devices in the Beryl LAN network from your home network, will require more port forwards and/or a DMZ setting on the Beryl.
Protocol: The protocol used, you can choose TCP, UDP, or both TCP and UDP.
External Zone: The options for external zone are WAN, WireGuard Client, WireGuard Server, OpenVPN Client, OpenVPN Server, LAN, Guest.
External Port: The numbers of external ports. You can enter a specific port number here. The port range is from 1 to 65535. You can set a single port or set the port range by concatenating the first and last port numbers with the - symbol (Such as 501-510).
Internal Zone: The options for internal zone are LAN, Guest, WireGuard Client, WireGuard Server, OpenVPN Client, OpenVPN Server, WAN.
Internal IP: The IP address assigned by the router to the device which needs to be accessed remotely. If you set a single port in External Port, you should set the single port here. If you set a port range in External Port, you should set the corresponding port range here.
Internal Port: The internal port number of the device. You can enter a specific port number. Leave it blank if it is same as the external port.
Description: Set a name or add a description for the port forwarding rule (optional).
