I’m trying to make it work on my AX1800 and for some reason only internet traffic goes through VPN tunnel.
wg.conf file I use for the router specifies the following:
[Interface]
Address = 192.168.10.5/32
ListenPort = 51542
PrivateKey = [key]
DNS = 192.168.10.1
MTU = 1420
I want to get access to 192.168.1.x and 192.168.2.x subnets via VPN too. If I use same config from my laptop directly everything is fine.
In the router I tried enabling / disabling IP masquerading, switching Autodetect and Global proxy mode and enabling / disabling Remote Access LAN. Using latest firmware v4.5.0
Watching this as I’m having the exact same issue. Like yourself, tried every combination of toggles, dns in the config, etc. Connects, but no access to the remote lan. Using the exact same settings in windows wireguard client, everything works perfect.
In my case, server side is the latest version of OPNSense, home network is on a 192.168.10.x subnet. Wireguard is using 10.50.50.x and local network on GL-AXT1800 is using 192.168.69.x.
Wireguard will connect, but there is no remote lan connectivity. Checking external IP, it will show remote network (server) side external IP.
It appears to be a DNS issue, even if it’s configured in wireguard to use remote DNS.
Using the exact same client configuration in the windows wireguard client on the same device, everything works perfect. Remote DNS works, can access network resources, etc.
When I first got the device, it auto-updated to 4.5.0. Since then, I’ve tried with 4.5.16 beta and just now did uboot back to 4.5.0 just to make sure it wasn’t an upgrade issue.
Problem still persists. Wireguard will connect, ipchicken returns remote network external IP, but no DNS resolution to remote network.
Windows wireguard client with exact same settings works perfectly.
192.168.1.0 and 192.168.2.0 are managed by OPNSense LAN networks.
192.169.10.0 is subnet of wireguard server for this VPN connection. 192.169.10.1 is ip address of OPNSense.
WG Server - OPNsense router, with 10.0.0.0/16 VLANs configured (10.0.0.0/24 is the main LAN)
It has WG interface configured to be 10.0.5.0/24 (WG clients connect into this range).
Gl.iNet (MT3000 v4.5.16) has local interface configured under 10.10.0.0/24 range.
When I have "IP masquerade" turned off - all the Gl.iNet clients can access home lan (behind OPNsense) via WG under the GL router's IP 10.0.5.5 (seen on the OPNsense).
However, I'd also like to access local devices behind GL router from within my home LAN (so 10.0.0.0/24 -> 10.10.0.0/24), that's why I would like to have "IP masquerade" OFF. But with it's off, I can't access home LAN (10.0.0.0/24) resources from clients behind GL router any more. And I see their real IP (10.10.0.0/24) in firewall logs as blocked by the default floating rule "Default deny / state violation rule".
Is my understanding and thinking of the configuration correct? Please point me in the correct direction
It is a year later, but this fix [adding the route in luci] worked for my use case as well, thanks for posting it. I was wondering if it ever made it into the firmware and if there was a more appropriate place for me to be making this routing override?
sorry for the delay @Hoodah@Shurov
In firmware 4.8, we have multiple VPN instance support. Currently, the direct route has the highest priority. The workaround should be adapted, and we need to reevaluate the changes.
