ill try that now should i plug in cable and then disable hotspot or disable first then connect?
tryied several times and ways and i keep getting error on router failed to connect should i try factory restoring the router or is there a way to “re-trust the ios device” and start from scratch? i hate to have to downgrade ios that is a big pita
tryied 2 different lightning cables (apple) and no luck i reset the router to factory still wont tether i re-trusted the phone to router connection and entered the password as asked not sure what else to try i see lots of folks saying that above 14ios it wont work ![]()
Do you press “connect” on tethering admin panel gl inet ?
Have you reset the router and try?
When you plug-in the cable from router to iPhone, it should pop up the trust window. It may have several seconds delay.
