Hi, I purchased a RTL8812BU [thinking it was an AU]. My bad. Is there any chance you can add this to the list? I plugged it in but light doesn’t come on and Kernel Log thinks it’s a high speed USB Device. I’m running latest 3.105. Incidentally, I tried toe included AU driver and it didn’t work.
It’s a BrosTrend AC3 V2 with a Realtek 8812BU chip inside.
Kernel Log Snip
[ 120.048578] usb 1-1: USB disconnect, device number 2
[ 132.385079] usb 1-1: new high-speed USB device number 3 using orion-ehci
[ 258.284747] usb 1-1: USB disconnect, device number 3
[ 271.244849] usb 1-1: new high-speed USB device number 4 using orion-ehci
That didn’t work. Light stays out but the logs look a little different Anyway, I appreciate your help. I’ll just go purchase another wifi dongle. BrumeW seems to be out of stock for a while now.
System Log
Thu Mar 4 08:52:50 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.1/1-1.1:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:52:50 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:52:50 2021 kern.info kernel: [ 22.377880] usbcore: registered new interface driver rtl8812au
Thu Mar 4 08:52:50 2021 daemon.info gl_mqtt_service[2730]: mqtt init success!
Thu Mar 4 08:52:51 2021 user.notice firewall: Reloading firewall due to ifup of wan (wan)
Thu Mar 4 08:52:52 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.1/1-1.1:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:52:52 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:52:52 2021 kern.info kernel: [ 24.705738] usbcore: registered new interface driver rtl8821au
Thu Mar 4 08:53:21 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.1/1-1.1:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:53:23 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:53:23 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.1/1-1.1:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:53:25 2021 kern.info kernel: [ 31.286590] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
Thu Mar 4 08:53:26 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:53:26 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.2/1-1.2:1.0/ieee80211/phy*/device/: No such file or directory
Thu Mar 4 08:53:26 2021 daemon.notice procd: /etc/rc.d/S99gl_mv1000_wifi: ls: /sys/devices/platform/soc/soc:internal-regs@d0000000/d005e000.usb/usb1/1-1/1-1.1/1-1.1:1.0/ieee80211/phy*/device/: No such file or directory
** Kernel Log **
[ 20.373083] mv88e6085 d0032004.mdio-mii:01 lan1: Link is Up - 1Gbps/Full - flow control rx/tx
[ 20.382291] br-lan: port 2(lan1) entered blocking state
[ 20.382837] mv88e6085 d0032004.mdio-mii:01 wan: Link is Up - 1Gbps/Full - flow control rx/tx
[ 20.387910] br-lan: port 2(lan1) entered forwarding state
[ 20.403879] IPv6: ADDRCONF(NETDEV_CHANGE): wan: link becomes ready
[ 20.410182] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
