I was wondering if it’s possible to use SQM (luci-app-sqm) with this device? I prefer to not install OpenWrt or other firmware manually so this device intruiged me. But can it run SQM (with cake algorithm) with the stock firmware? And if so I would also appreciate help on how to set this up.
I can install it
And there is Luci interface
But one problem, I don’t think cake works on kernel 4.4.60.
You can try the firmware of kernel 5.4.
I’m on the latest 4.x kernel image and it worked fine when I was using ethernet uplink, but if its enabled on the STA wireless interface it won’t connect to the upstream wifi.
Hope this gets fixed.
