I know this topic has been covered in my topics however I cannot find a resolution for me.
I'm running Wireguard Server on my Flint2 router running 4.7.7 fw.
VPN works as I can connect to it remotely and access the internet via the VPN, but not my LAN resources on 192.168.2.0/24
Router LAN config: 192.168.2.0/24
LAN Gateway: 192.168.2.1
Wireguard Svr config: 10.0.0.1/24
2 Wireguard clients are defined 10.0.0.2/24 and 10.0.0.3/24 and both can connect to the VPN successfully and the internet via the VPN but not the LAN ressources and various hosts.
in WG Server options.
- Remote LAN access : enabled
- IP masqueradiing : disabled
- Client to client :disabled.
No route rules are defined either (I've tried with no success either)
is it possible to access both the internet and my LAN ? what routing config must I add and where, using GUI or Luci.
Thanks !
