I use a Beryl and everything was working fine but now, I cannot access to the admin panel at http://192.168.8.1. I see a message “It works !” instead of the login page. I was able to access to admin panel until I reboot the router. The only change I made was to install and enable file and multimedia sharing.
I had a similar issue yesterday but resolved it by resetting the router to factory settings and it was working fine after (previous issue occured after I tried to setup Apache server and entered the following command ln -s /mnt/mydisk/ /www/mydisk)
I tried with a different browsers. I tried with a PC then an Android device. Same result.
I do not know how to access to the directory /var/log/lighttpd/error.log or /etc/lighttpd/lighttpd.conf) when I am connected to SSH. I see no directory at all with command ls. I might do something completely wrong as I am not an expert in Linux, sorry
You can input the command: cat /var/log/lighttpd/error.log
When you connect to ssh, the ssh client will go to the “root” directory.
There are usually no files in the “root” directory. Please use ls / or cd / first and then ls.
Configuration is pretty simple:
I use the Beryl as a repeater from Wifi network. Only very basic system access to it: mobile phones, android or Apple tablets… The most advanced system is a PC but it does not have any web server on it.
I also use VPN (iVPN).
I tried to test with the URL 192.168.8.1 on the Wifi network in case but it just timed out
