Hi All,
I’m actually tring to configure access to my modem UI on internal network.
When the “Block Non-VPN Traffic” is enabled I cannot access to https://10.0.0.1 also if the IP is in the same subnet of my gli.
Please find below a draw of actual configuration.
Do you have any suggestion to leave the “Block Non-VPN Traffic” active but mantaining access to modem?
Thank you so much
Please not all together!
I’m sure I’m doing something trivial wrong
alzhao
September 28, 2023, 6:02am
3
Can you check this solution
This looks like the issue I have, kinda sucks I basically can’t use the internet kill switch if i need to access the lan
I’m new on the forum., is this likely going to take a long time to implement? i’ve just read that i could get a different device from my slate a1300 and downgrade to a v3 firmware that was more “logical” with exceptions for VPN policies.
Currently “Block Non-VPN Traffic” will void the “allow access wan” option. You need to configure in luci to achieve what you need.
Thanks a lot @alzhao !!!
I’m trying to do it and I will let you know
Hello @alzhao , it works!
Thank you so much!
