Getting error: " The following two devices, the WAN IP of the first device is conflicted with the LAN IP of the second device:" even subnets do not overlap. Tried to change them couple of times. Removing the first device from S2S just removes error message but the second device still does not connect. When starting S2S with AXT1800 added getting error -1001 briefly. The setting icon on S2S map does not work for this device. Factory reset did not help. Other thinks seems to be normal for this router except S2S
Could you please provide all the IP addresses of the devices? So WAN and LAN?
LANs are on the screenshot except ATX1800 which does not show it for some reason. It is 192.168.18.0/24
Main router and the last two are on home network 192.168.3.0/24
GL10 is on 192.168.100.0/24
GL8 is on 192.168.0.0/24
Routing tables from each device
GL11
root@GL-MT1300:~# route -n
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.3.1 0.0.0.0 UG 20 0 0 apcli0
172.30.55.2 0.0.0.0 255.255.255.255 UH 80 0 0 wg1
172.30.55.3 0.0.0.0 255.255.255.255 UH 80 0 0 wg1
172.30.55.4 0.0.0.0 255.255.255.255 UH 80 0 0 wg1
192.168.3.0 0.0.0.0 255.255.255.0 U 20 0 0 apcli0
192.168.8.0 0.0.0.0 255.255.255.0 U 80 0 0 wg1
192.168.10.0 0.0.0.0 255.255.255.0 U 80 0 0 wg1
192.168.11.0 0.0.0.0 255.255.255.0 U 0 0 0 br-lan
192.168.12.0 0.0.0.0 255.255.255.0 U 0 0 0 br-guest
GL8
root@GL-AR750S:~# route -n
0.0.0.0 192.168.0.1 0.0.0.0 UG 10 0 0 eth0.2
10.0.0.0 0.0.0.0 255.255.255.0 U 0 0 0 wg0
172.30.55.0 0.0.0.0 255.255.255.0 U 80 0 0 wg1
192.168.0.0 0.0.0.0 255.255.255.0 U 10 0 0 eth0.2
192.168.8.0 0.0.0.0 255.255.255.0 U 0 0 0 br-lan
192.168.11.0 0.0.0.0 255.255.255.0 U 80 0 0 wg1
GL10
0.0.0.0 192.168.100.1 0.0.0.0 UG 20 0 0 apclix0
10.11.12.0 0.0.0.0 255.255.255.0 U 0 0 0 wg0
192.168.9.0 0.0.0.0 255.255.255.0 U 0 0 0 br-guest
192.168.10.0 0.0.0.0 255.255.255.0 U 0 0 0 br-lan
192.168.100.0 0.0.0.0 255.255.255.0 U 20 0 0 apclix0
GL20
root@GL-A1300:~# route -n
0.0.0.0 192.168.3.1 0.0.0.0 UG 20 0 0 wlan-sta0
192.168.3.0 0.0.0.0 255.255.255.0 U 20 0 0 wlan-sta0
192.168.20.0 0.0.0.0 255.255.255.0 U 0 0 0 br-lan
GL18
root@GL-AXT1800:~# route -n
192.168.3.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan-sta0
192.168.18.0 0.0.0.0 255.255.255.0 U 0 0 0 br-lan
Also removing “conflicting” node GL20 from S2S does not fix the issue with GL18
Resolved by downgrading from v4.5.0 to 4.2.3
