thep
May 17, 2016, 2:42am
Cannot change macaddress on MT300A !!!
whenever i use option macaddr ‘***********’ in wireless file in config folder</span>
"daemon.notice netifd: radio0 (4438): nl80211 driver initialization failed.
daemon.notice netifd: radio0 (4438): wlan0: interface state UNINITIALIZED->DISABLED"
wireless interface stop on reboot !
+macchanger dont work
ifconfig wlan0 down
macchanger -A wlan0
i get ERROR: Can’t change MAC: interface up or not permission: Invalid argument
help!
Do you mean MT300N? MT300A should work with mac address changes.
thep
May 17, 2016, 4:08pm
3
MT300A on 2.20 its not working at all! please help!
changing macaddress on ethernet and lan is working but on wifi is not possible
After a thorough test, I have to say that MT300A doesn’t support changing mac address in repeater mode. I made some mistakes in my previous test.
thep
May 17, 2016, 6:29pm
5
so there is no way at all ?!
when ar300m will cm out?
AR300M is nearly ready.
Changing mac address when combined sta and ap in MTK chips seems a problem. Maybe this is because of the wifi driver, not the chips. Just don’t have a clue now.
thep
May 18, 2016, 4:29pm
7
so anyway to change the wifi driver?
will the ar300m have sdcard?
alzhao
May 19, 2016, 11:02am
8
The wifi driver is opensource, so it is possible. But need very good technical skills to debug.
AR300M doesn’t have sd card, but it has 128MB NAND flash.
