I’m new to the VPN subject with somewhat limited IT experience.
I just received my brandnew AX1800 Flint and connected it via LAN to my Speedport modem. I followed the instructions “First Time Setup” and were able to connect my PC via WLAN to GL-AX1800-2c8. Internet access is working as it should.
However, I’m not able to connect to the AX1800 via http://192.168.8.1 - " Die Website ist nicht erreichbar, Die Antwort von 192.168.8.1 hat zu lange gedauert."
I switched to Admin account on my PC and disabled Norton. No change.
I tried Firefox, Chrome and Edge. No chage.
The label shows the WiFi-Key, so it should be a new version.
as Admon wrote, disconnecting the LAN cable, power-on reset and the connection got established. Now I could enter username an pw.
Now I’m trying to get OVPN setup, I’m working through the tutorials right now - we’ll see if I need mor assistance.
Thanks for the help.
Now the WLAN properties with the correct IP of the AX look like:
