I set my OpenPVN configuration for CyberGhost as was suggested in this tutorial. Only using the individual ZIP file for my login credentials downloaded from CyberGhost gave me errors about a misformed ovpn file where key and certificate details were missing.
Now my GL AX1800 with firmware 4.4.6 gives me these error messages which make me think the issue lies not with the configuration file, but somewhere else as it complains about missing files an directories. This configuration file works on a different router with OpenWRT. Maybe someone has an idea how I can solve this problem, many thanks in advance
"Mon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Rule 'process_mark'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Rule 'wan_in_conn_mark'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Rule 'lan_in_conn_mark_restore'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Rule 'out_conn_mark_restore'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Zone 'lan'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Zone 'wan'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Zone 'guest'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Zone 'ovpnclient'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Set tcp_ecn to off\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Set tcp_syncookies to on\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Set tcp_window_scaling to on\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Running script '/etc/firewall.nat6'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Running script '/etc/firewall.vpn_server_policy.sh'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Running script '/etc/firewall.swap_wan_in_conn_mark.sh'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Running script '/var/etc/gls2s.include'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): ! Skipping due to path error: No such file or directory\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): * Running script '/usr/bin/gl_block.sh'\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): Failed to parse json data: unexpected character\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): uci: Entry not found\nMon Nov 27 21:01:07 2023 daemon.notice netifd: ovpnclient (1599): cat: can't open '/tmp/run/ovpn_resolved_ip': No such file or directory\n"
