Hello there,
So I got a interesting situation currently I have setup a bridge with two DSA vlans 1 and 90 on openwrt 22.02 on the flint release 3 firmware from github.
In openwrt I made two different interfaces:
- tvnet which shares a 172.18.x.x ip address from vlan 1.
- zigbee_net which shares 10.33.xx.x ip address from vlan 90.
The zigbee_net interface also gets covered by the wireless network.
So far everything works and every device gets the correct settings, so I can confirm that the vlans just work fine.
Until with one device which is a mi smart clock, when I go through the setup via google home on my phone, I can make the clock make connection to my wireless AP, but then it also wants to find my own device inside the network and that fails even if I connect to the wireless AP myself.
I have tried to enable multicast… And igmp snooping but for some reason I keep getting the warning that the AP is isolated inside the google home app, though inside the bridge settings there is a checkbox called port isolation which is unchecked (default value)
So far I think with the bare configuration on the bridge it should not be isolated unless I’m missing something with 22.02 since DSA is very new in openwrt ![]()
I’m confused why this is, could it be a internal script which turns my access point into a guest wireless access point?
Thanks ![]()
