keep getting this error message when trying to install pia openvpn on my mt300n router
OpenVpn is not started
Last log WARNING: ‘link-mtu’ is used inconsistently, local=‘link-mtu 1558’, remote=‘link-mtu 1542’ WARNING: ‘cipher’ is used inconsistently, local=‘cipher AES-128-CBC’, remote=‘cipher BF-CBC’ [64e392b389aa8ea3df9ce2ad15a6f44c] Peer Connection Initiated with [AF_INET]104.238.169.91:1198 AUTH: Received control message: AUTH_FAILED SIGTERM[soft,auth-failure] received, process exiting
Have you double checked your login credentials (ie. does the user/pass work using the PIA client)? Your username/password are not the same as your PIA forum ones!
In the log it says the cipher setting is different. I checked the ovpn files and the cipher is aes-128-cbc
While the log says that the server is BF-CBC. Seems PIA changed cipher. Generally the server support different settings and it should work. But I am not sure this is the reason as it is only warning. You need to check your credentials as well.
just want to say a big thankyou to everyone on this thread, I have got the pia vpn working on both routers.
1 more question, now there running, if I plug the router into the back of my isp router and then Ethernet to my mag box, will the vpn work or will I need to connect to pc and start it again?
So…what was the exact problem? Kindly share for others.
Regarding your question, if the VPN is started on the GL router (only need to do it once from the GUI by clicking enable), then anything connected will run throught the VPN.
router just went off and now it will not connect again, saying the following
<table style=“border: 0px; min-width: 400px; border-spacing: 5px; margin-left: 20px; color: #ffffff; font-family: arial, helvetica, verdana, sans-serif, ‘Microsoft YaHei’, 微软雅黑, ‘Heiti SC’, 宋体, STXihei, serif; font-size: 14px; background-color: #295873; height: 163px;” width=“1037”>
<tbody>
<tr>
<td>OpenVpn is</td>
<td>not started</td>
</tr>
<tr>
<td style=“white-space: pre-wrap;”>Last log</td>
<td>WARNING: ‘link-mtu’ is used inconsistently, local=‘link-mtu 1558’, remote=‘link-mtu 1542’ WARNING: ‘cipher’ is used inconsistently, local=‘cipher AES-128-CBC’, remote=‘cipher BF-CBC’ [75a25737510cffe2ad1a7b352ffad256] Peer Connection Initiated with [AF_INET]104.238.169.60:1198 AUTH: Received control message: AUTH_FAILED SIGTERM[soft,auth-failure] received, process exiting</td>
</tr>
<tr>
<td style=“color: yellow;” colspan=“2”>Please setup custom DNS to prevent DNS leaks
