your router version maybe is 3.0, the 3.0 router version use samba server is 3.6, it can’t support the SMB2, only support SMB1. set min protocol=SM2 not work. GL AXT1800 router version is 4.0, it support the SM2 default
thanks but still not working and to make it more complex, now there is an open question:
with the official glinit firmware 3.212, using default samba 3.6,
is SMB2 supported or not supported?
in the mean time, tried this and still now working
— updated these two files /etc/samba/smb.conf.template /etc/samba/smb.conf
with
min protocol = SMB2
max protocol = SMB3
and then did /etc/init.d/samba restart
and then rebooted and hard powered off
on the client, testing on two machines, both W11.PRO
and get this result
net use \\192.168.8.1\koq
System error 384 has occurred.
You can't connect to the file share because it's not secure. This share requires the obsolete SMB1 protocol, which is unsafe and could expose your system to attack.
— smb.conf
[global]
netbios name = GL-AR750S
display charset = UTF-8
interfaces = lo br-lan
server string = GL-AR750S-326
unix charset = UTF-8
workgroup = WORKGROUP
browseable = yes
deadtime = 30
domain master = yes
encrypt passwords = true
enable core files = no
guest account = nobody
guest ok = yes
invalid users = root
local master = yes
load printers = no
map to guest = Bad User
min protocol = SMB2
max protocol = SMB3
min receivefile size = 16384
null passwords = yes
obey pam restrictions = yes
os level = 20
passdb backend = smbpasswd
preferred master = yes
printable = no
security = user
smb encrypt = disabled
smb passwd file = /etc/samba/smbpasswd
socket options = TCP_NODELAY IPTOS_LOWDELAY
syslog = 2
use sendfile = yes
writeable = yes
[homes]
comment = Home Directories
browsable = no
read only = no
create mode = 0750
[GL-Samba]
path = /mnt/sdb1
read only = yes
guest ok = yes
browseable = yes
[koq]
path = /root/rclone/mountpoints/main/01
read only = yes
guest ok = yes
browseable = yes
— smb.conf.template
[global]
netbios name = |NAME|
display charset = |CHARSET|
interfaces = |INTERFACES|
server string = |DESCRIPTION|
unix charset = |CHARSET|
workgroup = |WORKGROUP|
browseable = yes
deadtime = 30
domain master = yes
guest ok = yes
local master = yes
load printers = no
min protocol = SMB2
max protocol = SMB3
os level = 20
printable = no
security = user
syslog = 2
use sendfile = yes
writeable = yes
