Hello!
I am attempting to use the wan access feature to connect with my AR300m running lede-gl-ar300m (2.243) and am having no luck.
From my GLI UI, I have wan access enabled on port 83, upnp enabled from the upnp tab in the router settings, and I have s/n required for login disabled.
When I type my uniqe address, I get to the authentication screen, but when I enter my
username: root
password: (my-gli-router-password)
it simply keeps asking for it again and again and again with no avail.
Am I using the correct login credentials?
I have also tried to change the wan access password, I have reset the router by holding the reset for 10 seconds. Nothing seems to work.
One thing to note is that from the wan access setup page, the blurb at the bottom shows the upnp is not active (it shows an x in a red circle).
Any help would be appreciated, thanks in advance!
