Cannot relink the GL-MT3000 to GoodCloud
After updating my MT3000's firmware from v4.8.1 to v4.9.1 Beta (OpenWrt 25) and completing all settings, it cannot reconnect to GoodCloud. Currently, GoodCloud shows the device as offline, but the firmware version remains v4.8.1. After removing the device from the list and reconnecting via the link provided in the management panel,
the device status shows "online," but the firmware version remains 4.8.1. Information such as the number of devices and remote SSH connection fails to load. Shortly after, the device status changes to "offline."
The device’s IP address is up-to-date. However, the management panel always shows the device as disconnected from GoodCloud, and is displayed the same image as Image 1. The same issue occurs when trying to connect using the iOS mobile app.
The problem persists even after multiple device restarts.
Currently, I haven't rolled back to version v4.8.1 because I'm still testing the new features.
Model: MT3000
Firmware Version: 4.9.1 (OpenWrt 25)
Thank you very much for your help.
Thank you for your reports.
Please check:
