After I installed the Tor firmware for my AR300M, I cannot update my software packages in Luci. When I hit the “Update Lists” button, the log follows:
Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/base/Packages.gz. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/base/Packages.sig. Signature check failed. Remove wrong Signature file. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/luci/Packages.gz. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/luci/Packages.sig. Signature check failed. Remove wrong Signature file. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/management/Packages.gz. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/management/Packages.sig. Signature check failed. Remove wrong Signature file. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/packages/Packages.gz. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/packages/Packages.sig. Signature check failed. Remove wrong Signature file. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/routing/Packages.gz. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/routing/Packages.sig. Signature check failed. Remove wrong Signature file. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/telephony/Packages.gz. Downloading http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/telephony/Packages.sig. Signature check failed. Remove wrong Signature file.
Collected errors: * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/base/Packages.gz, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/base/Packages.sig, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/luci/Packages.gz, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/luci/Packages.sig, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/management/Packages.gz, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/management/Packages.sig, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/packages/Packages.gz, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/packages/Packages.sig, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/routing/Packages.gz, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/routing/Packages.sig, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/telephony/Packages.gz, wget returned 8. * opkg_download: Failed to download http://www.gl-inet.com/openwrt/ar71xx_nand/tor/1.3/packages/telephony/Packages.sig, wget returned 8.`
