I try to set up WG server on Flint 2 v4.5.6.
Once connected to the WG server, my device can’t access LAN nor WAN.
What could be wrong?
I found out. Incoming connections could not reach Flint 2 because I forgot to set a static IP that match my modem DMZ.
If that is the case, Wireguard client should not connect at all.
You are right. The client gave no error nowadays.
All works fine now (I’m connected to it right now).
