Loving my MV 1000 Brume / I have it set up as a wireguard server, sitting behind my (master) ISP router - I’m able to access all of my network peripherals from outside - everything is (almost) perfect.
Question/Problem - surely I’m doing something silly - when connected to the “master” ISP router inside my home, or even connected to the MV1000 via Wireguard, I can see everything EXCEPT the MV1000 itself - - it’s almost never a problem, unless I have to reconfigure the WG clients, reboot, check logs, etc… What am I doing wrong?
The only way I can access the WM1000 is by hard wiring into it - even if I’m inside, connected to the “master” ISP router, I can not connect. I can get a PING - - but no connection can be made - - - is there something in Lucy I don’t have installed??
In my case, WG Server MUST be active.
I MUST be connected by a WG Client - even on my own network.
Yes, you are totally right - I must use the Tunnel Subnet…
So, I guess I have a solution… I was just confused that I couldn’t access the Brume through the network, WITHOUT the WG Server running…
Thank you so much - I really appreciate it Antifascista
Excellent answer! I had totally forgotten… I’m kind of a “set it and forget it” type, so I haven’t looked at my set up in a few years - - but this sure rings a bell - - thanks so much for your thorough answer with documentation link to boot…!
