Can't connect to 192.168.8.1
Using both a Windows laptop and an Apple mini m2 and Chrome I can not connect to 192.168.8.1 both timed out: 192.168.8.1 took too long to respond.
Are you sure that your router is reachable on this IP or did you change anything?
In case of doubt, reset the router.
Try clear IP address in your setting network (remove static IP, leave empty)
