I have my ISP router with a dynamic IP. It only supports OpenVPN. I created a configuration file and injected that configuration file into my phone with OpenVPN (it's working) and I wanted to inject the configuration file into my Beryl router serving as a client. But when I start my OpenVPN client I get the following:
Fri Aug 2 22:16:37 2024 daemon.warn ovpnclient[17832]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Aug 2 22:16:37 2024 daemon.notice ovpnclient[17832]: TCP/UDP: Preserving recently used remote address: [AF_INET]38.89.150.229:1194
Fri Aug 2 22:16:37 2024 daemon.notice ovpnclient[17832]: UDP link local: (not bound)
Fri Aug 2 22:16:37 2024 daemon.notice ovpnclient[17832]: UDP link remote: [AF_INET]38.89.150.229:1194
Fri Aug 2 22:17:37 2024 daemon.err ovpnclient[17832]: TLS Error: TLS key negotiation failed to occur within 60 seconds (check your network connectivity)
Fri Aug 2 22:17:37 2024 daemon.err ovpnclient[17832]: TLS Error: TLS handshake failed
Fri Aug 2 22:17:37 2024 daemon.notice ovpnclient[17832]: SIGHUP[soft,tls-error] received, process restarting
Fri Aug 2 22:17:37 2024 daemon.warn ovpnclient[17832]: WARNING: Compression for receiving enabled. Compression has been used in the past to break encryption. Sent packets are not compressed unless "allow-compression yes" is also set.
Fri Aug 2 22:17:37 2024 daemon.notice ovpnclient[17832]: OpenVPN 2.5.3 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD]
Fri Aug 2 22:17:37 2024 daemon.notice ovpnclient[17832]: library versions: OpenSSL 1.1.1q 5 Jul 2022, LZO 2.10
Fri Aug 2 22:17:42 2024 daemon.warn ovpnclient[17832]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Aug 2 22:17:42 2024 daemon.notice ovpnclient[17832]: TCP/UDP: Preserving recently used remote address: [AF_INET]38.89.150.229:1194
Fri Aug 2 22:17:42 2024 daemon.notice ovpnclient[17832]: UDP link local: (not bound)
Fri Aug 2 22:17:42 2024 daemon.notice ovpnclient[17832]: UDP link remote: [AF_INET]38.89.150.229:1194
I'm testing the OpenVPN client Beryl which is connected to my ISP router at home as well.
