Hi, cant find any beta 4.71 for XE-300 and also Esim manager does not appear anywhere in this router
This one firmrware does not have any esim manager, please post a ink for 4.7.1 and XE300/puli
openwrt-xe300-4.3.23-1107-1730944851.tar
Do you insert an eSIM card?
The eSIM Manager will only be displayed when inserting eSIM card.
i inserted official EIOT club simcard into XE300, but nothing appears, even when rebooting, on phone itself iot simcaard app is crap i cannot even add esim qr code in it.
This page on setting up an eSIM has links to the relevant downloads.
On the XE-300 be aware that the ESIM isn't supported on the Quectel EP06-A module version, which is why I replaced the module with an EG25-G one.
How to i get info if its EP06 inside ? and why GL inet dont say anything about this before buying their XE300 routers : (
The XE300 routers have been available for quite some time before the eSIM was announced/supported, which makes it hard to describe conflicts for products that haven't even been thought of at the time.
All the descriptions of the eSIM in both the sales web pages and the product instructions all contain this type of disclaimer :
I own a XE-300 with the Quectel EP06-A modem and I am wondering if there is any chance/hope that Qualcomm will ever add support for the missing AT commands to the Quectel EP06-A to support eSIM and that a future GL.iNet firmware update will fix it? Or does this basically mean the XE-300 with the Quectel EP06-A will never support eSIM and if one wants eSIM, it definitely means one needs to purchase new hardware? Thanks
Yes, since this one module lacks esim AT commands, GL firmware cannot support and control about esim for this module, and also may not be able to support it later.
Please purchase models that support esim.
The EG25-G modules are quite cheap through AliExpress, which is what I used.
Cheers.
