Hi there,
I'm currently using the Flint for my home router and configuring an Opal for my travel router to work remotely. I'm able to get most of the way but am running into issues when trying to change the endpoint in the config file to use my DDNS address. If I use the DDNS config file for the VPN client on the travel router, I run in the "The client is starting, please wait..." message and it never resolves.
I did notice when I check the Use DDNS Domain to create the wireguard client configuration file, it doesn't seem to stay checked. I'm not sure if that matters?
In addition, I configured the port forwarding on the flint to allow the opal to connect. However, if I enable it then wireguard doesn't seem to work even with the non DDNS configuration file on the client side.
Any suggestions would be much appreciated!
