Can't install 6to4 6in4 etc. kmod-sit not available also ddns glddns.com not working
Hi there,
I own a Mt6000 Flint2 and i want to install the 6to4 package and 6in4 package.
While installing i get the message: pkg_hash_check_unresolved: cannot find dependency kmod-sit for 6in4
  • pkg_hash_fetch_best_installation_candidate: Packages for 6in4 found, but incompatible with the architectures configured
  • pkg_hash_check_unresolved: cannot find dependency kmod-sit for 6to4
  • pkg_hash_fetch_best_installation_candidate: Packages for 6to4 found, but incompatible with the architectures configured.
I have done a new firmware install 4.5.8 and even 4.6.0 but the answer is the same, what can be done?
Also when i setup the dynamic dns from glddns.com it's not working, in luci i see the setup is missing (no username password etc.) but i can't find how to retrieve this information.
Some help please!
With kind regards
You don't need those information, just enable GLDDNS from GL GUI.
Thanks for your reply, also for some magical reason it's started to work yesterday.
Now i only have the isue how do i get the 6to4, 6in4 installed with luci/software?
I go to our customer tickets system just now and check the email, cannot find the email about this issue and your name.
It does not matter, I saw this thread. We will check it out and fix it if it is a issue, kindly await.
4.5.8/4.6.0 feeds source has been upgraded.
Likewise, 4.6.0-op24-0607 also.
Check it please.
Bruce,
Thank you for your response.
I have updated the opkg package list en after that i was able to install the 6to4 6in4 packeges.
Thanks for the effort.
With kind regards!
docker is having installation problems, could you check?
Could you share screenshot or post error logs which the installation of docker? And please let me know your firmware version and router model.
this in all versions based on kernel 5.4.238. There are some packages missing from the repository. Could you please check?
MT6000
Got it, have reported into the development plan, kindly await.
now it worked to install docker.
thank you very much.
If any other app appears with missing packages or incompatibility, I will report it to you.
sqm is having the same problem... could you check?
We will add the missing packages as soon as possible
I had to reset my router today en now the problem has returned.
Can't install the 6to4 6in4 (kmod-sit missing) and now i can't even install ddns-scripts.
I have updated the opkg list but no luck.
Can you check please why it's missing again?
WIth kind regards
The package repository has been updated, please try again.
I Have updated the repository and was able to install the 6in4 6to4 packages but with the ddns-script also for the ddns-cloudflare etc. script i get this error:
error-opkg
What can be done?
Please try to install ddns-scripts(2.8.2-12), and we will try to update ddns-scripts(2.8.2-43).
This was where i clikcked on the install button from luci.
afterwards i downloaded 2 script files (ddbs-scriptsn ddns-services) and installed these manualy.
Now i can set som features
