I have just received a MT300N-V2
It worked correctly the first time: I have connected to 192.168.8.1, I have updated firmware, I have setup OpenVPN, and it was behaving correctly.
Then I tried setting the mode switch slider to “openvpn”, it would say that the setting was applied, but then when I got back to the homepage the slider was set again to “nothing”.
I rebooted the router, but now even though the router works (it is correctly connected to the OpenVPN account and I have traffic) I can’t connect to the GUI interface anymore. When I type the ip address 192.168.8.1 in the browser it will just respond as “unable to connect”.
I haven’t changed the LAN IP, and I have also looked inside my network connections, and the router’s ip still is 192.168.8.1, so the address is correct.
What’s wrong? What should I do?
Thanks
