can't reset GL-SFT1200
Person who did the initial setup (incorrectly) did not write down the admin password. Instructions say to:
"hold down the rest button for ten seconds then release to reset the router to factory settings. The light will turn blue and
flash rapidly. all data is cleared when light becomes solid blue."
well blue light has been pulsing every 2 seconds for ten minutes? I still see old network IDs on the chromebook?
How do i reset this?
Lenk
Check this Repair or Reset - GL.iNet Router Docs 4 first and if it does not work (or if it's already the one you followed) go with Uboot debrick Debrick via Uboot - GL.iNet Router Docs 4 instead.
