I bougth a GL-A1300 Slate Plus, I’ve configured the wireguard client to connect to my UDM SE wireguard server.
I have access to the local network using the IP’s, but not using the DNS.
in the configuration of the wireguard I have the DNS server correct, because if I connect my Smartphone directly to the wireguard server, I can use the DNS of my local network.
what should I change in the GL to be able to use the local DNS?
I tried with AD guard on and OFF but I want to use Ad guard on the GL.
thank you in advance, for your help
Ivan
