Can't setup Open VPN
Hi there,
Been totally happy with my Opal OpenVPN client (except for its inability to connect to iPhone) + ASUS server setup.
Recently moved offices - I updated the OpenVPN config file but still can't seem to locate the router. The new office has a static IP address, so the updated config looks like this:
remote xxx.x.xxx.xx 1194
Any idea to make the OpenVPN connection work again? Thank you
(Can still see and remote manage my Opal via Goodcloud and all)
It seems that your new place blocks OpenVPN. Could it be possible?
I have no idea but can ask (it's a shared office). So even if I can remote access my router, it could still be blocked? Is there any way around it?
GoodCloud does not rely on VPN, so yes, possible.
Would Wireguard work instead?
It depends on what the reason is why it does not work.
I'm guessing it's not so much blocking.
With Shared Offices, can Opal be reached via the Shared Office public IP? (I don't believe I can control that IP via my Opal)
P.S. Assuming that's the case, will Tailscale solve that?
