I’ve downloaded and tried to install the update various times without any luck, both from the app and browser.
How can I install this update?
I’m currently on 3.105
Please copy the image to the router via scp,then log in to the router and execute the subordinate screenshot command.
Ok. How do I copy the image via scp? And where and how do I execute the command?
I ran the commands. What now?
Thanks
Yes, it is equal to your screenshot.
I test it is ok. If you can’t upgrade from 3.105 to 3.107,maybe I need to check the situation remotely via ‘teamview or anydesk’.And Can you leave your contact information for better communication, such as Skype.
