Canvas sometimes glitches out
I noticed a issue with canvas which renders the screen on the web ui, on my Comet pro fw 1.7.0.
This often seem to happen when the browser is idle or the page is not focused, this results in a loading screen but then results in a white canvas but it breaks because it does not recover.
When I use my password manager alot of times the idle times are enough to replicate it.
I see this happen on the Brave browser on Android (Poco X6 pro).
try using normal mode instead of smart mode?
I suspect that some browsers have not fully implemented WebRTC, causing them to be unable to actively request the KVM to update the screen when the display is abnormal.
At least Chrome doesn’t have such issue
It seem to work with setting it to direct.
What is strange is that brave is a fork of chromium only it is still on manifest 2, is webrtc also working on Chrome on the mobile version?
The Brave browser includes a built-in setting that provides a choice of four levels of protection against WebRTC leak.
It may be caused by its built-in plugins.
