When I have the captive portal enabled on my B1300 I cannot connect to my VPN provider over the wifi network from either my android app or OpenVPN desktop client. Regular browsing after portal authentication works fine. VPN connections when the portal is disabled work fine as well.
Is there a firewall rule preventing this that could be modified?
To be clear: I’m referring to using mobile/desktop clients for VPN providers that are completely separate from the software included in the router admin console. The router is functioning neither as VPN server nor client in this instance; I am trying to pass 3rd party VPN traffic through the router after authenticating the captive portal.
I have utilized these VPN clients/servers on public wifi networks that utilize a captive portal without issue. I’m curious as to how/why the GL.iNet would prevent connections even after authenticating.
Hopefully you’ve sorted this out by now but if not, the captive portal uses nodogsplash and the settings, including the allowed ports are in /etc/config/nodogsplash
This is a bug that we will fix in the next version. I will give you a manual repair method, you need to SSH to the router and modify /etc/congfig/nodogsplash file and then run the command /etc/init.d/nodogsplash restart. @jeremypetersen
